Old-Biscuit
Oct 02, 2013Explorer III
The 'red light' comes on only when a 'fault' occurs......
On propane it will come on IF
Propane fails to ignite/prove flame OR ECO T-stat (high temp) has opened
And on electric IF
ECO T-stat has opened
Sounds like your normal t-stat is not opening when reaching pre-set temp (140*F)
Could be loose/corroded contacts/terminals on normal t-stat or normal t-stat is not making good contact with tank wall
Change out your normal t-stat.
And on electric IF
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
