Old-Biscuit
Oct 02, 2013Explorer III
You'll find replacement t-stats come in a set...ECO/Normal with new foam cover
The ECO & Normal have different size terminal lugs so you don't have to worry about mixing them up.
Disconnect wires to t-stats (brown..Normal red..ECO)
Remove the foam cover
Then you have to bend the three small tabs back that secure the t-stats
Remove old t-stat
Place new t-stat against tank wall
Compress plastic washer
Bend tabs back down to secure t-stat tightly against tank wall
Install new foam cover
Plug wires back onto t-stats
Biggest pain is getting tabs bent back down while holding plastic washer/spring down.....fat fingers makes it even more fun :B
Remove old t-stat
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
