kampinguru
May 08, 2018Explorer
Red light on Water heater disply
I have a suburban 10 GAL DSI water heater. I run it on propane. When I turn on the switch, the burner will light but sometime after that, I will notice the lite between the pump and heater button on the display is lit and the water is not hot. I cycle the switch and the light goes out and the burner lights again. Any idea what might cause that lite to come on. I suspect it is the same as the error light on the fridge. It tells you when there is a problem with it lighting.
