wa8yxm
Jun 18, 2020Explorer III
CA Traveler wrote:
There is no wire color standard for RV's. As a guess for white black black is + and for white red red is +. My rig has a lot of whire wires that are +.
The only sure way is to find where the wires go.
Like CA said. the standard. well there is no standard.
Now.. Two suggestions
one is to use a volt meter. Meter between FRAME and wires.. With and without tow vehicle hooked up and engine running.. With and without shore power connected.
if it's positive. it's positive.
Alas you may have a pair that does not give you any reading
if so those are likely the electric jacks.. You may need to find the jack controller if any to identify which is which based on the terminal label.
Now Using heat shrink tubing. tape or nail polish
ALL THE POSITIVE WIRES Get dressed in RED
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
