Bobbo
Jun 18, 2020Explorer III
Boon Docker wrote:
Set your multimeter to ohms. Ground one probe to the frame then touch the other probe to each wire separately.
A reading of zero to 1 ohm means that wire is negative.
Be sure that no wires are connected to the battery's positive terminal. Touch a hot wire like this and you will damage the meter.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
