swimmer_spe
Jun 18, 2020Explorer
Bobbo wrote:Boon Docker wrote:
Set your multimeter to ohms. Ground one probe to the frame then touch the other probe to each wire separately.
A reading of zero to 1 ohm means that wire is negative.
Be sure that no wires are connected to the battery's positive terminal. Touch a hot wire like this and you will damage the meter.
I know how to use one. I was hoping that it would have been simple as white is always ... The idea of the ohm test on the frame and wires will help.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
