CA_Traveler
Jun 19, 2020Explorer III
Ohm test is a start but may not be adequate and yield low ohms on both - and + wires. The option I use is a series load and I've used a light bulb as suggested. You may need a load that draws more amps and find and turn off switches etc that could lead to false conclusions on the positive side.
Once the weres are connected With a 50 year old RV it would also be a good idea to leave a heavy draw load in series while while you turn on and test everything inside with the view that the series load will have a voltage drop.
That second set of wires could also be for trailer brakes.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
