Chris_Bryant
Feb 16, 2015Explorer II
The OPD valves will not pass LP unless a hose is hooked up- you can open the valve, and nothing will come out. The pigtails have collars that melt at a low temperature, which allow the pigtail end to pull out, shutting the flow in case of fire. The other check valves are in the pigtail- they are excess flow valves, which will shut the flow in case of a line break- they will also shut off if the valve is opened to quickly. To reset these, the valves must be shut, hoses disconnected to equalize all pressures.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
