Baja_Man's avatar
Baja_Man
Refer fans for improved cooling...what are the best options?
I have a Norcold N843 8cf refer with ice maker. It works well. However, when ambient temps get up to 95-105F, it struggles to stay cold. It will only cool to 46F when ambient temps are at 100F and side of RV with refer is directly facing sun.
So, since I can't control weather, and can't always predict how my RV will be parked when visiting campgrounds (facing sun), I want to ensure that my refer has all the things it needs to stay as cold as possible.
I've read about two types of fans installed to assist with cooling...
1. A fan on the evaporator (inside refer) to move the cool air around on the inside of refer and prevent frost build up on evaporator fins
2. Fans on rear on refer between the back side of refer and exterior RV side. These are used to assist with moving hot air up and out of roof vent.
The rear fans can be difficult to install if choosing to mount above coils since access is only through exterior vent lid (without removing refer).
Questions...
REAR FANS:
1. Where should rear fans be placed for most effective outcome? Above coils, on coils, below coils, etc?
2. Which fans have been proven to be most effective...computer fans, Valterra type of fan, etc?
3. Should fans be thermostatically controlled or manually with a on/off switch, or both?
4. How should these fans be wired? 12V power and ground from refer wiring OR separate 12V and ground wiring pulled from somewhere else?
INSIDE FANS:
1. should these fans be the hard wired ones that are wired to inside light OR the D battery operated type, or is there something else?
2. Are inside fans necessary or can good results be had with only the rear fans
Any other tips, suggestions or ???
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
