MEXICOWANDERER
Nov 02, 2022Explorer
- Refilled bottles must be verified by weight. Stuffed bottles can vent wildly which is dangerous
- Stow bottles to be refilled in the freezer to speed refilling
- Liquid LPG hose with an inline **** valve is the easiest to manage
- Check filled bottles for weight
- Use a top tapper to bleed excess weight. Do not touch the small vent hole. They will almost always leak if you do
- Submerge in water to check for leaks.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
