flyfishing48's avatar
flyfishing48
Refirig fan questions
I have a question about our refrigerator. I have a digital thermometer inside on the upper shelf and a small battery operated fan on the middle shelf. The temperatures have been showing 34 - 46 degrees. I have the temperature set for the coldest setting (5). When the outdoor temps are above 70 degrees I don't see the temps inside the refig getting below 41 degrees. If the outdoor temps drop into the 60's or lower (mostly at night now) then the refig will get into the 30's. But all day (when the temps are in the 80's ) it is mostly showing 45 degrees. We are not opening the door a bunch. No grand kids with us right now.
I pulled the covers off the slide and had a look inside at the back of the refig. I see there is a fan near the top, but I have yet to see it running. There is a set of fins at the very top and on the one end is what appears to be a thermostatic switch. The mounting screws were loose and the switch was not making firm contact with the fin. I remedied that situation but I think the cooler night temperatures helped more.
When should I expect to see that fan run?
Dometic DM2862LBFX in a slide.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 22, 2025
