rockhillmanor
May 29, 2013Explorer II
harold1946 wrote:
With dead batteries none of the controls for the refer will work, all need dc power.
The ac will trick you sometimes and send you down all different paths as to what is wrong throwing the symptoms to a problem off. Did for me.
The ac will come on but when the thermostat reaches it's desired temp and shuts off....it can't come back on with out 12V.
So if it never reaches it's set temp it will keep running and then you think I don't have a 12v problem cause the ac works!! Sent me in circles. Was bad converter for me. Not putting out enough V was not it's problem, it was putting out SO much uncontrollably it was french frying the battery!!
To the OP: No fridge, no ac, battery will not hold charge.....check the output of the converter.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
