time2roll
May 29, 2013Nomad
If you are plugged in, the converter or inverter/charger should still supply the fridge with 12 volts even with a bad battery. Usually.
I think the voltage can sag to 10.5 volts (maybe lower) and the fridge board will still keep the cold going.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
