Old-Biscuit
Nov 29, 2020Explorer III
'Check Light' only has to do with Propane operation
Means flame failed to light off and Prove it lit
If you are in AUTO Mode....
AC Power is priority
BUT on LOSS of AC Power fridge will swap to GAS
If Gas fails...Check Light
IF in AUTO and you are SURE there have NOT been any Power Outages then Circuit Board is funky due to getting wet
IF you have propane valved in and flame is lighting then issue is with the Flame Proving signal which could be bad Spark Electrode wiring/connection OR circuit board is funky from being wet
You can completely remove circuit board *label/disconnect all wires/leads (AC/DC/Element Leads etc)
Then dry both sides using hair dryer
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
