MitchF150
Nov 30, 2020Nomad
Yeah.. I still say the board.. Mine would work fine when on 12v only. Plug into 120v and it would work fine until it needed to cycle. Then, it would shut off and throw the check light.
I have more problems with cooling my fridge when it's HOT outside. I have my fridge in a slide, so it needs an upper vent to expel the heat.. Since heat rises and does not like to go sideways, I have to provide additional fans to push that heat out the side..
Anyway, the board only costs $100 give or take and solved my problem.. And even it does not solve yours.... Well, you have a backup board for when it does fail..
I know, not your cut and dry answer to your problem, but that's all I got for ya.. :)
Good luck! Mitch
Good luck! Mitch
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
