MEXICOWANDERER's avatar
Jun 05, 2015
Refrigeration Temperature Pet Peeve
It took me several bouts of food poisoning to realize propane powered refrigeration and tropical climates do not mix. Food that "seems" cold might be perfect lab conditions for food poisoning pathogens to grow. This is especially true of gas refrigerator ineffective operation on foodstuffs stored on door shelves. I went to the FDA website and cut and will paste below their verbatim recommendations for food storage recommendations. Door storage temperature is key. So are various measurements all around the inside of the refrigerator. With freon now doing the work, this issue has gone the way of the gooney bird for me...
Storage Basics
Refrigerate or freeze perishables right away. Foods that require refrigeration should be put in the refrigerator as soon as you get them home. Stick to the "two-hour rule" for leaving items needing refrigeration out at room temperature. Never allow meat, poultry, seafood, eggs, or produce or other foods that require refrigeration to sit at room temperature for more than two hours—one hour if the air temperature is above 90° F. This also applies to items such as leftovers, "doggie bags," and take-out foods. Also, when putting food away, don't crowd the refrigerator or freezer so tightly that air can't circulate.
Keep your appliances at the proper temperatures. Keep the refrigerator temperature at or below 40° F (4° C). The freezer temperature should be 0° F (-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these temperatures and are generally inexpensive.
Check storage directions on labels. Many items other than meats, vegetables, and dairy products need to be kept cold. If you've neglected to properly refrigerate something, it's usually best to throw it out.
Use ready-to-eat foods as soon as possible. Refrigerated ready-to-eat foods such as luncheon meats should be used as soon as possible. The longer they're stored in the refrigerator, the more chance Listeria, a bacterium that causes foodborne illness, can grow, especially if the refrigerator temperature is above 40° F (4° C).
Be alert for spoiled food. Anything that looks or smells suspicious should be thrown out. Mold is a sign of spoilage. It can grow even under refrigeration. Mold is not a major health threat, but it can make food unappetizing. The safest practice is to discard food that is moldy.
Be aware that food can make you very sick even when it doesn't look, smell, or taste spoiled. That's because foodborne illnesses are caused by pathogenic bacteria, which are different from the spoilage bacteria that make foods "go bad." Many pathogenic organisms are present in raw or undercooked meat, poultry, seafood, milk, and eggs; unclean water; and on fruits and vegetables. Keeping these foods properly chilled will slow the growth of bacteria.
Following the other recommended food handling practices (clean your hands, surfaces and produce, separate raw foods from ready-to-eat foods, and cook to safe temperatures) will further reduce your risk of getting sick.
  • My Kenmore had little ducts that forced cold air across the door shelves... which was quite effective, from what I could tell. Maybe I should consider a fridge fan for my lp fridge, after all. hmmm, there goes another 8-12Ah's a day.
  • My big honkin' household refrigerator does the same thing- stuff in the doors is warmer.
