Why would the mfr wire it too small?
Seems like EVERYTHING having to do with wiring in this Palomino Bronco is wrong, sub-standard, a mess, or haphazard!
I can't believe how much wiring I've fixed. In some areas, black is negative and in others white is negative! And then there is a smattering of red and green just to make it interesting!
Thanks for all the help on this. I guess I'll just leave it alone and use propane. I was trying to conserve propane on long drive. I typically can drive 12-16 hours at a stretch. If the 12V would keep the frozen food frozen, this would be better than using propane.
