scubakerny's avatar
scubakerny
Refrigerator Blowing Breaker
My frig will run on 30 amp no problem, but when I plug the trailer into a normal 110 outlet it blows the breaker. I took the side panel off and saw the frig was plugged into a local outlet behind the cover. I tried plugging it in directly to a 110 house outlet and it blew again. Have tried multiple outlet tests and different locations and still have the same issue. Would like to be able to plug the fridge in to cool down before we leave without having to use gas.
Any help would be appreciated
  • MrWizard wrote:
    You turned off the water heater
    And the converter/ charger ?
    If so
    Heating element is shorted out to ground
    Replace the heating element
    X2. Cartridge heaters often open, but they can short, too. The heater is the only part of the circuit that could trip a high-amperage breaker.
  • If you're tripping the house circuit breaker
    Using only the fridge on an extension cord
    There are other items in the house on the circuit and your 3 amps from the fridge is over load
    But i think the heating element in the fridge is leaking to ground and needs to be replaced
    Time to use propane until you replace that heating element
  • If I understand what you are saying, you unplugged the fridge from the outlet behind the fridge and plugged it (via extension cord?) directly to your house outlet and it still tripped the house breaker.
    If it trips the house breaker when connected directly to a house outlet I don't know why it would not trip the breaker on your internal trailer distribution panel when connected normally and plugged into a 30 amp outlet. The fridge AC power should be wired from one of your trailer distribution panel 15 or 20 amp sub circuit breakers. What are the amp ratings of the "house breakers" you are tripping?
  • One thing that most people don't realize is that a thermal breaker wears out over time, especially it it trips once in a while.
  • 30 amps is a normal 110 outlet. It is simply wired using heavier duty wire. A standard household outlet while 120VAC not 110 VAC is 15 or 20 amps. If your blowing a breaker it means your drawing too much power. Reduce useage. Turn the converter off, be sure the water heater is off. Then, if its still tripping the breaker check the electric element on the refer. Possibly it is dieing.
  • Exactly where did you plug into 30 amps?
    Plugging into a marginally overloaded house receptacle circuit breaker branch will send it over the edge. So will a connection to a marginal circuit breaker. They do get old and weak.
    Try shutting off ALL breakers in the rig except the one to the refrigerator. That should exclude what isn't the problem.
  • You turned off the water heater
    If so
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
