MitchF150
Jun 04, 2020Nomad
I've got my fridge in the slide, so it has the top side vent. When I first fired up the fridge, it didn't cool that well, and that top vent area was really HOT running on gas or electric.
I got this dual fan setup and hacked it in. It has wired control unit to adjust the fan speed, set it on a timed run, or on all the time or auto which uses a temp sensor. Works great and I just put the control unit in the lower vent access as I didn't want to mess with cutting holes in the wall and once I set it on auto and the fridge is on, I just want it running anyway.
It does turn the fans off when the fridge cycles off, so that's 'cool'..
It runs on 12v and I just tapped into the 12v leads from the wiring to the fridge in the lower access.
I don't have an internal fan. Have not felt the need for that. Keeps the fridge and BEER nice and cold. In the 36-38* range, even on hot days.
Keeping the inside of the rig cool (running the A/C) helps a lot too.
Good luck! Mitch
Good luck! Mitch
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
