crcr's avatar
crcr
Refrigerator no longer works on Propane -- Need Advice
2011 TT with a Norcold refrigerator. Always worked great on both 110v and propane. Now suddenly still works great on electric, but won't cool at all on propane.
I did my best to troubleshoot the problem, and ended up replacing the propane regulator and the propane burner, which includes the orifice. I have a nice blue flame, but, no mas, it still doesn't cool on propane, only on 110v. I'm looking for advice as to what might be the problem and/or what to investigate next. Thanks in advance for any tips!
  • enblethen wrote:
    Yes! Sometimes rust and carbon will fall onto the baffle causing a blockage. Only need t get 4-6 inches up into the 3/4 inch pipe to knock it loose.
    Model of refer would help.
    Thank you. Norcold N611FR
    What I see above the flame is sheet metal that is 3 to 4" in diameter. So is the 3/4" pipe you speak of inside that round sheet metal enclosure?
  • Yes! Sometimes rust and carbon will fall onto the baffle causing a blockage. Only need t get 4-6 inches up into the 3/4 inch pipe to knock it loose.
  • enblethen wrote:
    Have you cleaned the stack?
    You can do a partial cleaning from the bottom with a flairly stiff wire like a metal coat hanger. There is a baffle a few inches up in the stack that makes the heat circulate in the stack. make sure you rattle the baffle!
    Thanks for your response. I did tap many times on the stack to try to get any soot, etc to fall down, but that's all I've done in that regard. So I guess to get further into the stack, I will need to take it apart as much as I in the small area of the refrigerator that is accessible from the back panel.
    Are you suggesting that I should try cleaning up into the stack, well beyond the small accessible area?
  • Have you cleaned the stack?
