buylow12's avatar
buylow12
Refrigerator Not As Cold As It Ought To Be
Hello everyone, back again after a while(Believe it or not I've been able to fix some stuff on my own ;) Anyways my Domestic Americana is not cooling as well as it should, particularly the fridge. The freezer is still keeping things frozen but my ice cream is soft, always a sign it's not as cool as it should be. However the refrigerator is only mildly cool and I'm going to have so food going bad if I can't figure this out. I switched it over to propane as I usually find that works better but it didn't make much difference. I also just removed both exterior vents and everything looks clear.
When I took them off though it occurred to me that I haven't heard the fan run in a while. Usually when it's hot out I can hear the little buzz of it running and I can't remember the last time I heard it. Is there a way to confirm the fan isn't working? Any particular fan I should replace it with? Is the fan being broken enough to cause this? I read the fan can increases efficiency by 40% somewhere so if that's true I'd think it could. Will leaving the vents off in the meantime help?
Well thanks as always for all the help and if you have anything else you think it could be or anything I should check please fire away ;)
