MrWizard
Apr 04, 2021Moderator
dougrainer wrote:MrWizard wrote:
If i release my parking brake, my levelers will retract,
Why would you want to release the parking brake , on a vehicle so large, with slides extended out like sails, you could end up rolling thru the campground, most likely into another camper
Powergear system and some LCI will release when the parking Brake is released, BUT, the key has to be turned on. If camped and the Ignition OFF, and you release, the jacks should not retract. If they do, the wiring is not to spec. Doug
Doug
You are correct and I failed to mention the key being on !
I was thinking of when he got in the
Drivers seat preparing to leave, turn on the key to power up the slides and because the parking brake has already been released the jacks retract, but the slides are out, he would no longer be level, and any good wind would be putting additional strain on the transmission parking paw ,
This is not a situation I would trust, This could damage the transmission if the MH moved,
Even more dangerous if the MH has kick down jacks, which have been know to give way and flip up, if the RV rolls forward, it's a feature which prevents damage to the jacks, if the RV is driven forward while the jacks are down
How ever it might be described, I think releasing the parking brake , while using leveling jacks and slides ,
Is Bad Idea
There is nothing in the chassis literature that says do Not use parking brake for ???? Or longer tHan xxx
PARKED STORED NOT BEING MOVED parking brake should be engaged
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
