BFL13
Mar 24, 2017Explorer II
The MBA is a "lower portion" of the power centre type of converter, not suitable to be moved up front. For that you want a "deck mount"
http://www.bestconverter.com/Boondocker-Main-Board-Assembly-for-WFCO-8955_c_196.html
So leave the converter as is, and get a second charger that is way better for fast charging using the generator, which would be the "adjustable voltage" deck mount style. You can make your own cables from a cut off set of #4 gauge jumper cables.
http://www.bestconverter.com/Boondocker-BPCM-75-75-Amp-Adjustable-Power-ConverterCharger_p_587.html#.WNVq8FJ1pLM
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
