BFL13
Mar 25, 2017Explorer II
johnm1 wrote:
The Boondocker BPCM-xx is safe to use all the time? Even when plugged in 24/7 at home?
Yes but you must change the voltage yourself, it is not an automatic 3-stageer like the one you have installed now. Best to use the 3 stage one on shore power and only use the ADJ one for fast charging on the generator.
BTW, the 75 takes all a 2000w gen can do so you might need to leave the converter in the trailer off or just don't plug in the trailer. A 3000w gen won't run both 75s going full bore.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
