BFL13
Mar 25, 2017Explorer II
Yes, if you leave the initial charging amps the same, and add more battery, it takes longer. More H in the AH. 50-90 is 40 percent. 40 percent of a bigger battery bank is more AH that needs replacing than 40 percent of a smaller bank.
It is proportional to the times in the ugly graph so four batts will take twice as long as two. Those times were with Vector portable chargers, so are "typical" times. If a charger only goes to 14.4 it will take longer than with 14.8 too.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
