SoundGuy
Mar 25, 2017Explorer
johnm1 wrote:
The Boondocker, et al. units are in the 75 amp range and the "biggest and best" CTEK is 25amps. It looks like your's is 7amp? That sounds like lots of generator run time.
Did I miss something?
Yeah, this isn't about me but about you. We normally camp on electric sites but from time to time find ourselves without shore power so to that end I have a 1000 watt PSW inverter that allows us to make coffee, toast, run a couple of fans, etc, just as we would when on shore power. Genset run time is a non-issue for me because I no longer have one and instead recharge when we get home so that 7 amp CTEK which does do a true 14.4 volt bulk charge is just the ticket for my particular situation. Babysit if you want, if it were me in your situation I'd be investing in a PD9260, mounting it in the front pass through cargo compartment, and letting it do it's job automatically.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
