mchero's avatar
mchero
Remote entry question
07 Fleetwood Discovery owner.
Noticed range on remote keyfob not good. I inspected the receiver under the center console and discovered the black antenna wire hanging out of the receiver broken. Looks like it was cut/broke during assembly of the dash.
Can someone with like setup measure your black antenna wire too get the total inches.
Also, the actuator in door has a rubber dust boot falling apart. Is their a place where i can order parts?
Thanks
  • I recently changed the battery in my 2012 truck key fob due to it getting weak. New battery and much better range.
  • Did you try changing the battery in the key fob. The fob I normally use is getting weak, I have to be within 10 feet of the cab (E450 chassis) before I can unlock or lock the door. Doesn't work from the back bumper of the MH. The other 3 fobs work normally, 50-100+ feet away.
    Ken
  • MDKMDK wrote:
    Did you try an internet search for Fleetwood RV dealers? Perhaps they might know the answers to your questions.
    https://www.fleetwoodrv.com/locate-rv-dealers
    Fleetwood dealer would be the last place I'd go.
    In due time a reader will see the post and respond
    Thanks for the reply.
  • maddog348 wrote:
    12 yr old unit ~~ just discovered an assembly issue ??
    Yes indeed a 12 year old "unit"
    No I did not just discover
    Thanks for the informative responce.
