eric1514's avatar
eric1514
Remote LP Shut-Off and Battery Usage
Some RVs have inaccessible propane tanks and require a remote electric solenoid valve to stop the flow of gas, the manual knob being unreachable. And some RVs have propane detectors that incorporate an electric shut-off also, like mine. If I turn the detector off or it senses gas, it will shut off the flow from the tank.
I was told the remote switch on some class Bs draw .75 amps while keeping the flow of gas going. Over a 24 hour period that's 18 amps. No big deal if you're plugged in, but if you're boondocking, that's a bunch just to run the fridge.
Is there a more economical and legal way to not use as much juice?
TIA,
Eric
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
