Mgr1001's avatar
Mgr1001
Removal of coroplast belly cover
Hi Y'all
:B
I'm toying with the idea of removing and replacing a large section of the belly cover from my fifth wheel toy hauler.
I want to do this for several reasons:
1- There is a plumbing leak that will be very difficult to locate and repair otherwise.
2- I have a concern about the tank supports for my fresh water holding tank. A while back I peeled away a section of the belly cover for another reason, and discovered that one of the supports had pulled away from the trailer frame. These tank supports are attached to the frame with self tapping screws in such a way that if the screws came loose, the tank could literally fall out of the bottom of the trailer.
3- Because of said plumbing leak, the belly cover is retaining water in a way that reminds me of an infants overfull diaper.
4- I would like access to all the systems covered by the belly cover.
Now, for my questions:
a- Is it okay to be on the road for a while without the belly cover (I,m in relatively warm, but rainy weather in the south)
b- It seems that the type of coroplast material most available to me is 48"x96"x4mm. Is this a proper replacement(Is it heavy enough)?
c- I'm considering adding cross bracing at the overlap points of the coroflex. Basically, angle iron long enough to span the width of the trailer screwed to the frame. I will attach a diagram if I can figure out how. Any comments/suggestions very welcome.
Thanks Mike
:h
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
