DougE
May 25, 2017Explorer
Remove Water Heater Plug
Last fall I was unable to get the water heater plug out to winterize the system. I ended up just blowing out all the lines with compressed air but could still hear water bubbling in the water heater tank. I figured the air trapped in the tank would be sufficient to allow freezing without damaging the tank and I guess that worked. However, any suggestions for removing the plug next year? I had a 1/2" electric (battery) impact wrench on it with no luck. I could see the remnants of Teflon tape on the plug so it had probably been out before. What about heating it with a plumbing torch? I've had success removing frozen bolts by heating them up for a minute. I do have an air impact wrench but was reluctant to try it as it's quite a bit stronger than the electric.
