LarryJM
Aug 31, 2013Explorer II
old guy wrote:
I just installed a fantastic fan and I used a plastic putty knife I bought at home depot. worked great, but you still have to be careful, the rubber roof is very fragile.
I found the exact opposite when I removed every spec of caulking on my rubber roof during my Eternabonding marathon. The membrane can be gouged without penetrating or cutting it as long as you aren't using something sharp. I found it to be very tough and resilient. I would however be careful since carelessness could damage it. Even so if you will be putting Eternabond over the area even a little damage is not a big deal IMO as long as it's not along the edge where the Eternabond will be applied.
Larry
