flyinguy68's avatar
flyinguy68
Repair of laundry spigot hook up
Hoping someone here can offer tip, trick or advice on dealing with a leaky spigot. I have googled many searches for repair tips & parts to no avail.
I have successfully done some minor residential bathroom & kitchen plumbing.
Problem is water leaking from the washer hookups in my 5th wheel. I was able to remove the handle on top but could proceed no further without concern for causing more damage. Appears to be a rubbery cylinder inside, and looks like it got a blister and ruptured.
Just looking for tips to take valve apart & repair. Wouldn't mind capping it as I do not use them, but I guess I have to be able to bleed them for winterizing.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    I don't know how those install, but if they unscrew like the residential ones, you can replace with better quality brass valves. But maybe they're on PEX with a crimp? If so, it's a bit more work but can still be adapted to brass.
  • Ditto. You could probably get them out, and might be able to disassemble them to the point of being able to get the washer out, and if you're really lucky, find a replacement washer that will work...
    I'd replace 'em though... It's really not worth the effort.
  • beemerphile1 wrote:
    Looks like typical poor quality junk used in RVs. I would remove both of them and install normal residential quality brass valves.
    That's what I was thinking.
  • Looks like typical poor quality junk used in RVs. I would remove both of them and install normal residential quality brass valves.
  • if the valve has a name on it? google it and se what comes up. I,ve never seen that style.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
