fj12ryder
Jan 21, 2018Explorer III
saraajmele wrote:The VP44 will run without the lift pump but it's a considerable strain on the pump. Plus if you lose pressure to the VP44, like changing the fuel filter, you won't be able to start the engine again. The VP44 pump can't overcome the air bubble to restart.
We have taken a look at Fass and airdog and realize they are mostly better than the stock Cummins part and are thinking of replacing the VP44 pump once we have the lift pump issue repaired. It will start and run without the lift pump working.
If the VP44 has run a fair amount without the lift pump operating then it's probably not a bad idea to replace it. You can get rebuilt pump for around $1000, but if you have to have it done out on the road you'll be looking at a service/parts bill of around $3000. I got my rebuilt pump for about $800, but that's been a few years ago. It's not terribly hard to install them, just a bit fiddly.
I have an Air Dog Raptor 100 running for over 5 years, but there are lots of complaints about the newer ones. I think if I had to replace mine, I would go with the FASS, even though it's a bit more expensive.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
