MrWizard
Jan 21, 2018Moderator
55watt lamp is a resistive load DC or AC volts it won't care
and it will reduce the current to lamps load
try the amp meter on the new lift pump without the lamp
just for a couple of minutes
less if you see the amps spike, shut it off
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
