4x4van
Oct 17, 2017Explorer III
Wow, talk about overthinking things. Pull any one of your 12vdc switches out and look at the back/side. I guarantee that they are rated in AC, not DC. There is no appreciable difference in the contacts of a household 120VAC switch and an automotive rocker switch, other than perhaps the size (household switch contacts will be larger).
The only way a DC current will "weld" contacts together is if the current is higher than the contacts are rated for; AC or DC makes no difference. 6A at 120VAC is equivalent to 60A at 12vdc.
Personally, I think household switches in an RV (along with the requisite cover plate) would be extremely ugly, but to each his own.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
