DrewE
Jun 07, 2020Explorer III
Yes indeed, pop rivets are super easy to install, arguably easier than screws (though of course harder to remove and impossible to reuse).
Consider yourself fortunate that you could get a replacement hinge. I had to replace one of the door hinges on my motorhome last year after an unfortuate encounter with a concrete barrier on a very tight bit of roadway with a good bit of traffic, and when I took the mangled one into my local RV dealer and parts place they actually had a little laugh at me for hoping to find a replacement hinge for the 20 year old door. I ended up having to make one using a vice, hammer, flat metal stock, and some brute force. It worked out rather better than I expected, functioning just fine, although it won't win any beauty contests!
At any rate, pop rivets are installed blind. Traditional rivets require a bucking block or bar on the back side to install, but they are not what is used in this case.
