dougrainer
Jan 11, 2016Nomad
joebedford wrote:dougrainer wrote:
The roller is NOT Schwintek supplied. But, you have to pull the slide room or hyper extend the room to replace or gain access to the rollers under a Schwintek slide box. Due to the lack of clearance on this type slide mount. You CANNOT attempt to lift the slide box up like on other slide rooms. Doug
Who supplies it if not Schwintek?
Surely the clearances on the slide aren't so close that I couldn't jack it up 1/4" to put in a new roller?
The OEM installs the rollers. You can jack up the room just a 1/4 inch, but you risk damaging the side Rack system and gears. The rollers are screwed to the floor using at least 1.5 inch screws. Why do you need to replace the roller? Doug
