newman fulltimer wrote:
Its a spring loaded shaft just pull one side releases the other side it pops out
They are NOT spring loaded. They have axle caps on each end. Doug- newman_fulltimeExplorer IIIts a spring loaded shaft just pull one side releases the other side it pops out
- The roller is NOT Schwintek supplied. But, you have to pull the slide room or hyper extend the room to replace or gain access to the rollers under a Schwintek slide box. Due to the lack of clearance on this type slide mount. You CANNOT attempt to lift the slide box up like on other slide rooms. Doug
