MrWizard's avatar
MrWizard
Moderator
Oct 28, 2017
replace slideout seal using 3M VHB tape ?
anybody use 3M double sided VHB tape to install a new seal
(you know the same stuff some of use to stick solar panel mounts to the roof)
instead of using, tacky adhesive from a tube ?
the question came up today in a conversation i was having with an acquaintance
and since i have a similar up coming chore to do
i though i would ask
  • i just ordered the Eternabond double sided, equivalent
    says to use for windows vents etc..
    50ft*1" roll off Amazon $34.88, should be here Weds Nov 1st
  • I've used it for RV slide seals, but not my own unit.
    There are a few varieties to be aware of. But we actually bought 15' from Menards for $10-15.
    From gray to black to foam like to thin clear tape...the 3M exterior rated varieties are excellent for exterior use.
  • yes wiper seal
    not all of them, this one 3" total width 5/8 bulb on the top
    No adhesive
    do have a 5oz tube (large tube) of 3M adhesive
    but seems like the VHB tape would be a less messy and faster option
  • Slideout seals come with an adhesive already on them.
  • I assume that you are talking about the wiper on the outside of the slide. Although I have never used the VHD for that purpose,I have used it for many other purposes and I am sure that it will work well to attach the wiper. When they say Very High Bond (VHB) they mean it.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
