Fleet_Man
Apr 15, 2015Explorer
The solenoids just screw into the manifold. You may need a strap wrench or small diameter filter wrench to break it loose if it is too tight to remove by hand. You should not lose any fluid when you remove the solenoid. Be careful not to damage or lose the "O"ring.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
