dougrainer
Apr 15, 2015Nomad
Fleet Man wrote:
The solenoids just screw into the manifold. You may need a strap wrench or small diameter filter wrench to break it loose if it is too tight to remove by hand. You should not lose any fluid when you remove the solenoid. Be careful not to damage or lose the "O"ring.
The new solenoid comes with new o rings. You cannot remove a solenoid and reinstall with the original o rings, removing the solenoid will cut the existing o rings no matter how careful you remove the solenoid. Doug
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
