Old-Biscuit
Nov 18, 2013Explorer III
Couple of things......
Are you operating the fridge in 'manual' mode (vs 'auto').
If so it will continue to cool & cool. Manual mode bypasses the pre-set thermostat control.
You fridge uses a pre-set thermostat (no temp adjustment on upper panel)
The 'thermistor' regulates temp in food section. It is a sensor that goes inside a plastic clip that is attached to cooling fin in food section.
The bulb of sensor should just protrude from top of plastic clip and it should be attached to right fin about mid-position.
Moving the plastic clip 'up' causes more cooling
Moving the plastic clip 'down' less cooling
If 'thermistor' is not in clip or on fin the fridge can cool continuously causing food section to freeze.
Same thing if 'thermistor' is bad.
You can test thermistor
Disconnect the thermistor harness from the P2, 2-pin terminal on the lower circuit board.
Place the thermistor in a glass of ice water, approximately 33°F to 35°F.
Wait 2 to 3 minutes.
You should get a reading of approximately 7,000 to 10,000 ohms
IF thermistor tests good and you are not using manual mode then the lower circuit board is the problem
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
