torinoscj429's avatar
torinoscj429
Cool Cat Replacement?
Hello All
I'm removing the terrible excuse for an air conditioner called the Cool Cat from my 99 Xplorer 230XLWT Class B motorhome. The thing is so noisy that I was relieved when it finally quit cooling last season, and I had a good reason to replace it with a household unit.
Has anyone else done this? From what I can tell, I'll need a "Wall" A/C with a sleeve, not a "Window" A/C, because the thing is buried in the top rear wall of the RV.
Anyone have any recommendations?
Thanks,
Gerard
  • Maybe go to WM and get one of those portable room AC units instead. About $200.
    john 'I am Canadian'
  • BarneyS wrote:
    Pop-ups use rooftop mounted air conditioners not ones mounted in a wall like you describe.
    Barney
    The new style A frame pop ups use a floor mounted Cool Cat.
    Gerard
  • Pop-ups use rooftop mounted air conditioners not ones mounted in a wall like you describe.
    Barney
  • BarneyS wrote:
    I think you may have more luck with this question in the Class B MH forum where you posted your other question. I will move it there. Good luck. :)
    Barney
    Could you please put this back into the old category? No other Class B motorhomes mount the Cool Cat like Xplorer did, and they only did it one year. Pop ups use this more than Class B motorhomes.
    Thanks, Gerard
  • I think you may have more luck with this question in the Class B MH forum where you posted your other question. I will move it there. Good luck. :)
    Barney
