ktmrfs
May 21, 2017Explorer III
one that may work and works quite well are the smaller panasonic true inverter microwaves. the small dorm sized one was within an inch of the size of the original microwave and narrower than the cabinet. old microwave trim kit worked well on it.
And since it varies magnetron power rather than cycling on and off when not in full power mode, generators like it better, heats better, and you can run it off a 1000W sine wave inverter at about 50 percent power.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
