dougrainer
Jun 21, 2019Nomad
Need to know the model control system(type wall tstat) of your Dometic. Did you use all the wires on the new motor? Some Motors have extra wires that are not utilized and are supposed to be capped off. Are you POSITIVE you connected the wires to the correct terminals at the capacitors and control board? When a fan motor acts as you state, it is usually a bad motor. From your story, do BOTH the old and new motor act the same way? I cannot tell for sure from your post. Doug
