Almot
Sep 13, 2018Explorer III
WillT wrote:
All padlocks, hitch lock, propane lock, bike lock, canoe lock, use the truck ignition key.
Did you have all your store-bought padlocks custom-keyed somewhere?
About those OP hatches - it doesn't even take a screwdriver to pry it open, a good rock would break a hole easily. Very thin fibeglass-ish panel. I've been thinking of reinforcing it inside with metal strips but never got around to doing this. The entry door is not much better, same fiberglass sandwich with foam inside, only the foam is thicker.
