SCADAMAN29325
Apr 10, 2023Explorer II
I'm trying to remove the furnace valve. How do I loosen this gas fitting?
There is the aluminum fitting on the left, the brass fitting in the middle and another brass thin fitting on the right up against the furnace wall.
Is the thin brass nut on the right supposed to be held still with a backing wrench while turning the brass middle fitting? Or holding aluminum fitting still on the left and turning the brass middle fitting?
Depending on which one is to be held still will determine which way I turn the middle fitting.
Thanks!
Thanks!
