dougrainer
Apr 11, 2023Nomad
You HAVE to pull the furnace. The brass nut ,you turn counter clockwise like any bolt type nut. PUSH down with the wrench. You can use the gray part of the valve as a back up, but since you are replacing the valve, the brass nut will break loose from knuckle power. Once the brass nut is completely loose you push it back into the RV to allow the furnace to be pulled. Doug
