lanahi
Sep 23, 2015Explorer
I have been looking for #51419 and #51427 which is what Atwood lists as the right part numbers. Is the 51732 hinge interchangeable? What is "the hinge part on the oven itself"? If I could find a picture of it, I would know if it is the right one or not.
The oven door closes until it hits the door seal at and near the top (which is correctly placed according to diagrams)and can't close any further. It's like the bottom of the door needs to be pulled out more in order for the door to close tight all the way up. If I push in the door at the top, it will close but not stay closed if I then quit pushing on it because it comes against the rubber seal. The bottom of the door needs to be pulled out to align it right, it seems to me.
Maybe this could somehow be adjusted?
