dougrainer
Sep 23, 2015Nomad
On these doors, IF by mistake you lift UP on the complete door, it pulls the hinges up and causes the door to appear not straight and hits at the top. With the door 1/2 way open, try to push the door at the hinges DOWN and see if those hinges slide downward and lock in place. IF the door has any tension, then the springs are OK. Doug
